A component using the getsockopt() function, with the SO_ERROR option, to check the health of a socket connection received a failing return code from the invocation. Look up the errno definition for a more specific cause.
Remove and ReInsert the I/O blade. If the problem persists, report to Extreme Switch support contact.
Error
A getsockopt() request discovered an error on a connection using file descriptor %sockfd% retuning errno %errnoNum%(%errnoStr%) for slot %slotNo% and conduit Type %conduitType%.
| Name | Type |
| slotNo | uInt |
| conduitType | String |
| sockfd | sInt |
| errnoNum | uInt |
| errnoStr | String |
